jj0n35
#1 Posted : Saturday, October 9, 2021 8:38:44 AM(UTC)
jj0n35
We are a new customer to vMix and are experiencing an issue where vMix seems to lock up the resources to our network interface completely. Details are below:
PC Specifications:
-CPU: Intel i9-10850K @ 3.6 GHz
-RAM: 64 GB
-Graphics: Radeon RX 570 (x2)
-OS: Windows 10 Pro
Intranet Path Specifications:
1 GB Ethernet NIC (Gigabyte embedded NIC in motherboard for PC described above) <--> Cat 6A <--> Ubiquiti 24-port managed switch <--> 10GB/e fiber <--> Ubiquiti 48-port managed switch <--> 10GB/e fiber <--> Ubiquiti Dream Machine Pro (router) <--> Cat 6A <--> ISP (cable) modem <--> ISP service <--> RTMP destination
ISP Specifications:
-600 MB/s (down)
-35 MB/s (up)
Full error history w/ video:
https://drive.google.com/drive/folders/1Uz5ThYOCm7Qtz2FyG1HYILwXpFsI-B76?usp=sharing
Error details:
24.0.0.71 - FFMPEG1.Exited - 10/8/2021 4:58:22 PM
kzzzzzx: Stream1: Unable to connect to streaming server.
Check the internet connection or Stream URL and try again. ---> kzzzzzx: Streaming
frame= 602 fps= 31 q=27.0 size= 11067kB time=00:00:20.05 bitrate=4521.8kbits/s
av_interleaved_write_frame(): Unknown error
frame= 572 fps= 31 q=27.0 size= 10558kB time=00:00:19.02 bitrate=4546.0kbits/s
frame= 587 fps= 31 q=27.0 size= 10795kB time=00:00:19.53 bitrate=4526.1kbits/s
Last message repeated 1 times
[flv @ 0b005200] Failed to update header with correct duration.
[flv @ 0b005200] Failed to update header with correct filesize.
frame= 605 fps= 31 q=27.0 Lsize= 11125kB time=00:00:20.13 bitrate=4526.0kbits/s
video:10809kB audio:299kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.147163%
[libx264 @ 0b006160] frame I:11 Avg QP:22.30 size:139741
[libx264 @ 0b006160] frame P:594 Avg QP:24.50 size: 16861
[libx264 @ 0b006160] mb I I16..4: 79.4% 0.0% 20.6%
[libx264 @ 0b006160] mb P I16..4: 18.9% 0.0% 0.0% P16..4: 10.6% 1.5% 0.5% 0.0% 0.0% skip:68.4%
[libx264 @ 0b006160] coded y,uvDC,uvAC intra: 78.2% 10.3% 2.0% inter: 4.6% 4.0% 0.2%
[libx264 @ 0b006160] i16 v,h,dc,p: 24% 16% 55% 6%
[libx264 @ 0b006160] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 24% 19% 4% 5% 4% 6% 4% 6%
[libx264 @ 0b006160] i8c dc,h,v,p: 83% 9% 7% 0%
[libx264 @ 0b006160] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 0b006160] kb/s:4578.28
Conversion failed!
--- End of inner exception stack trace ---
When this error occurs, the PC that vMix is installed on is completely unreachable from our internal network until after a full reboot of the PC. Other PC's however, have no issue connecting to our RTMP service provider or anywhere else for that matter. We can run other livestream software packages from this same hardware over the same network and to the same RTMP destination with no issues. We like the vMix GUI better than others, but will not be able to continue a subscription unless this issue is solved.
Also - there are no logs generated in Windows Event Manager when this happens - only after the fact when other services are unable to connect to anything.
Please let me know what other information you need to help us bring this to a resolution. If there are some settings on vMix that we have misconfigured, that's fine - we just need to know how to fix it.
Thanks!
-Jason
gre2gor
#2 Posted : Saturday, October 9, 2021 3:59:45 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
I am of no kind of an expert, but I would try some USB3 Network adapter as a first thing (to eliminate any motherboard/integrated NIC related problem). If I saw right, you are not using Nvidia? Can you turn off hardware coding for streaming?
Those would be my self diagnosing steps, until experts give you some better advice/solution.
grega
thanks 1 user thanked gre2gor for this useful post.
jj0n35 on 10/22/2021(UTC)
mikesg
#3 Posted : Monday, October 11, 2021 4:37:39 AM(UTC)
mikesg
Is the NIC actually using a Gigabyte driver? I would update the driver from the OEM (Intel, Broadcom, etc.) because that's easy to do. Is the lockup intermittent or can you replicate on demand? This may be a symptom and not the cause. I'm wondering about the AMD cards too. Could be happening when encoding starts.
thanks 1 user thanked mikesg for this useful post.
SportsNetUSA.net
#4 Posted : Monday, October 11, 2021 7:13:00 AM(UTC)
SportsNetUSA.net
AMD GPUs and duo GPU configurations are not recommended by vMix.
thanks 1 user thanked SportsNetUSA.net for this useful post.
jj0n35
#5 Posted : Friday, October 22, 2021 2:19:11 AM(UTC)
jj0n35
Thanks for your suggestion. The NIC driver is the latest Intel driver. I can replicate on demand and have obtained a PCAP during the crash to see if there's anything in there that would give a clue as to why this happens. Initially I thought that maybe excessive logical ports were being opened to manage the stream and then entered a TIME_WAIT or CLOSE_WAIT status that prevented reuse for a bit. That is not the case.
The only thing I have found so far is malformed RTMP requests sent from vMix on every PCAP of a crash that I have viewed. There are significantly more malformed packets sent on when vMix crashes than when it does not crash, but I can't seem to correlate that with adequate evidence to the locking up of the entire Ethernet NIC where no software on the machine can use that interface until a reboot. Something is seriously wrong here, despite the non-Nvidia graphics cards.
We're going to discontinue use of vMix for now - we lost another broadcast last night and I'm not willing to go down that road any further until a remedy is found. I do plan to switch to a single Nvidia graphics card but have serious concerns regarding that being a potential fix for these symptoms.
Thanks to everyone so far for your comments.
jj0n35
#6 Posted : Friday, October 22, 2021 2:23:03 AM(UTC)
jj0n35
grega
I may add a secondary Ethernet NIC and see how the system behaves during / after a crash of vMix when there are multiple NIC's available. I probably will not use USB3, though, I have a 10GB PCIe card that I might try...
Thanks again!
jj0n35
#7 Posted : Friday, October 22, 2021 2:25:13 AM(UTC)
jj0n35
Yeah - I saw that... seems very strange to me, but maybe just because those configurations have not been tested by vMix, and therefore cannot be officially recommended? IDK... still seems strange.
Thanks!
Guest (6)
