Audio Fades on Triggers/Shortcuts
I've got a Overlay shortcut set up (on a streamdeck) for an audio track, and on that audio track I have a trigger set up to SetVolumeFade OnOverlayIn, to fade the music up to 50% over 5 seconds and it works great.
Trigger: OnOverlayIn Function: SetVolumeFade Input: Music Track A Value: 50, 5000
What I'm having trouble with, is fading it out when I punch the shortcut again.
I did set up an OnOverlayOut trigger on the same track:
Trigger: OnOverlayOut Function: SetVolumeFade Input: Music Track A Value: 0, 2000
but when I punch the shortcut again, the audio cuts out instantly, while the fader does slide down to 0 over the 2 seconds, per the trigger specs.
Anyone have any suggestions?
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Try adding a 100 msec delay on the OverlayOut trigger. I had a similar issue.
