Tullo_rjs
#1 Posted : Thursday, October 7, 2021 9:30:53 AM(UTC)
Tullo_rjs
Italy
hi
i use very much mix2 3 and 4 as m/e to have a bus to destinate to stage screens or boxes in compositions.
For example, when i want to go live with a video in a PIP passing through mix2, it doesn't start by itself. Also, the same happens if i put a "transition out" property in a trigger in the video input: if this is a list, and i want to automatically skip after transition out, the trigger doesn't work if i'm on air with a PIP with mix2.
So i think that it can be useful to have a menu in which we can choose on what mix autoplay or the events "transition in/out" ect. (that make the trigger starts) should refer to.
Right now, we can choose what mix the trigger will affect, i want to choose what mix has the event that causes the trigger
