Martinius
#1 Posted : Friday, October 1, 2021 2:51:47 AM(UTC)
Martinius
Austria
I would like to connect the custom Buttons on New PTZOptics Superjoy Stick (IP Version) with vmix in order to fe. put fade (shortcut done in vmix) on one Button and so on.
Ptz Optics Support says that IF Vmix can handle UDP, TCP or HTTP commands then it would work....
So, anybody done something like connection through one of these?
And if it does, where can I find any documentation how to do that?
Martinius
#2 Posted : Saturday, October 9, 2021 3:50:17 AM(UTC)
Martinius
Austria
Hello
I found the solution to connect with vmix.
The Custom Buttons 1-4 can "fire" http Commants, that means you can use all Shortcuts of Vmix!
Go to the webinterface of the SuperJoy
Use YOUR set IP Adress of the SuperJOy
IN my case it is this adress for the Button 1
http://192.168.100.105/custom-btn1.html
In the URL Text Box write something like:
http://192.168.100.103:8088/api?Function=Fade&Input=1
That commant would set our Camera 1 from Preview to Live... and so on.
Or
http://192.168.100.103:8088/api?Function=OverlayInput1In&Input=4
Would set the Input / Slide with Nr. 4 as Overlay1 Live...
Easy if you know how to set Shortcuts in Vmix
