Good morning, class!! Anyone else having issues with data sources, generate simple Exel spreadsheet, load in data sources, add any title from vmix but don't update title when I change data.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: PedroMoynier  Good morning, class!! Anyone else having issues with data sources, generate simple Exel spreadsheet, load in data sources, add any title from vmix but don't update title when I change data. No issues here Maybe show the specifics, settings etc especially how you linked to a title
Joined: 10/23/2020(UTC) Posts: 9   Location: PA Thanks: 4 times
One thing to note about Excel data source is that you must save the changes for the update to work. It does not update automatically when you move out of the edited cell. The reason for this is that Excel holds edits in a TMP file until save. I've tried using OneDrive version, but that does not work similar to google sheets.
