I'm pointing vMix to an XML file that looks like this, but getting nothing back. Am I missing something? Tried a few different xpaths, nothing.
<?xml version="1.0" encoding="UTF-8" standalone="true"?>
-<SCOREBOARD_DATA xmlns="RXNevcoScore">
<HUNDREDTHS_SECONDS/>
<MAIN_TIME>24:12</MAIN_TIME>
<AUX_TIME>35:48</AUX_TIME>
<SECONDS_TIME> 0:18</SECONDS_TIME>
<HOME_SCORE/>
<HOME_POSSESSION_INDICATOR>0</HOME_POSSESSION_INDICATOR>
<HOME_TIMEOUTS_LEFT/>
<GUEST_SCORE/>
<GUEST_POSSESSION_INDICATOR>0</GUEST_POSSESSION_INDICATOR>
<GUEST_TIMEOUTS_LEFT/>
<GLOBAL_DATA_GAME_PERIOD>1</GLOBAL_DATA_GAME_PERIOD>
<GLOBAL_DATA_BALL_ON/>
<GLOBAL_DATA_YARDS_TO_GO/>
<GLOBAL_DATA_DOWN/>
<GLOBAL_DATA_END_OF_PERIOD_INDICATOR>0</GLOBAL_DATA_END_OF_PERIOD_INDICATOR>
<GLOBAL_DATA_SHIFT_SECONDS>24</GLOBAL_DATA_SHIFT_SECONDS>
<GLOBAL_DATA_SHIFT_TENTH_SECONDS>1</GLOBAL_DATA_SHIFT_TENTH_SECONDS>
<GLOBAL_DATA_HORN>0</GLOBAL_DATA_HORN>
<DISPLAY_CONTROL_DIMMING_STATE>9</DISPLAY_CONTROL_DIMMING_STATE>
</SCOREBOARD_DATA>
Blank or Error ? for starters it gives me a XML declaration invalid, and invalid root level and .... do you create the XML file yourself ? https://www.xmlvalidation.com/
Thanks for the link...looks like it does have a syntax error in the first line so I'll see if I can fix that. The file is live generated/updated by Nevco Decryptor which is translating scoreboard data to XML.
