Joined: 2/27/2013(UTC) Posts: 312   Thanks: 8 times Was thanked: 78 time(s) in 43 post(s)
Not sure if this has been requested but a Luma Keyer would be really handy for the churches that we work with.
This would allow lyrics on a black background to be keyed out and overlaid on video.
Thanks!
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 756
thecloudmediagroup wrote:Not sure if this has been requested but a Luma Keyer would be really handy for the churches that we work with.
Thanks! There are programs on line that does all that, can not remember the names, ...It comes with hymns and songs, even the Bile in different translations....all you need to do is make a Google search,.. If you have individual texts that you wish to do on your own, do it in photoshop, and save as PNG, or do it directly in Fireworks, since this saves as PNG... and they can be added as overlays or just plain images, and if you want to use a background for these images, just use multi View option in the background settings (small cog)...and let the type be number 2...
For sure! Pretty much all of our clients use those programs. There is EasyWorship, ProPresenter, SongShowPlus, ect.
The problem is that when they are captured through desktop capture or through a capture card, they do not have a transparent background which makes it tough to chroma out especially when doing a background capture.
