Feature Requests
Exposure, Vibrance Feature
Joined: 5/16/2014(UTC) Posts: 6 Location: Dominica 767
I Believe a Eposure control and vibrance feature needs to be added,
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
But if that functions could be on a floating window to prevent opening and closing the color correction tool... would be much better.....
Cheers,
PFBM
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
PFBM wrote:But if that functions could be on a floating window to prevent opening and closing the color correction tool... would be much better.....
Cheers,
PFBM Or, maybe, an icon just for colour Correction ONLY...... Also, the icons for the Audio Mixer could be moved to the bottom of the Sliders rather than alongside....At the bottom, will allow for a more narrow Audio Mixer, allowing it to use less lateral decktop space
HI !!
i found out a workaround.... but only if you have a magewell card.... you can open all the hdmi/sdi input control windows on the magewell card, where you have the same or better image control than vmix has. and it´s hardware not software..... and ... it works :) keep them opened on a second lcd monitor , side by side with the first monitor with vmix :)
Video Processing : Color Space Switch
De-interlacing:
Vertical filter de-interlacing; motion-adaptive de-interlacing
Image Scale:
Hardware 5-Tap scale
Image Mirror
Horizontal; vertical
Image Clip: Yes
Image Adjustment:
Brightness/contrast/hue adjustment/ saturation adjustment/control of monochrome and color/ Gamma adjustment separately adjust the brightness and contrast of R/G/B
Cheers,
PFBM
Feature Requests
