#1 Posted : Monday, March 8, 2021 3:24:32 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
24.0.0.49
* Fixes VST3 issue in .47 and .48
thanks 13 users thanked admin for this useful post.
eduardocfs on 3/8/2021(UTC), stigaard on 3/8/2021(UTC), Roi on 3/8/2021(UTC), supratman on 3/8/2021(UTC), dunk on 3/8/2021(UTC), sinc747 on 3/11/2021(UTC), KnightHeart on 3/11/2021(UTC), boris9831 on 3/12/2021(UTC), edhorn on 3/20/2021(UTC), R_L on 4/12/2021(UTC), avsoundguy on 6/15/2021(UTC), jet on 10/11/2021(UTC), kevine on 11/16/2021(UTC)
#2 Posted : Wednesday, March 10, 2021 3:15:59 PM(UTC)
24.0.0.50
* Added alert for not recording!
* Fixed issue with shortcut MoveMultiViewOverlay when used in Triggers with borders enabled
* Shortcut function search now has focus, so you can start typing without needing to click the search box
thanks 20 users thanked admin for this useful post.
doggy on 3/10/2021(UTC), Roi on 3/10/2021(UTC), DWAM on 3/10/2021(UTC), Castaway Studios on 3/10/2021(UTC), Simsyuk on 3/10/2021(UTC), Buenos Aires Streaming on 3/10/2021(UTC), sinc747 on 3/11/2021(UTC), monamiga on 3/11/2021(UTC), John Barson on 3/11/2021(UTC), KnightHeart on 3/11/2021(UTC), dwstutzman on 3/11/2021(UTC), pete242 on 3/11/2021(UTC), dunk on 3/11/2021(UTC), boris9831 on 3/12/2021(UTC), stigaard on 3/17/2021(UTC), edhorn on 3/20/2021(UTC), R_L on 4/12/2021(UTC), eduardocfs on 6/4/2021(UTC), avsoundguy on 6/15/2021(UTC), jet on 10/11/2021(UTC)
#3 Posted : Sunday, March 14, 2021 6:09:24 PM(UTC)
24.0.0.51
* Replay: If events are playing back, replay will no longer jump to the frames of newly created events, which would end playback of events in the process.
* Fix for issue with Sony VISCA over IP connection hanging in situations where another app or NDI is already using the protocol.
* When switching to a GT title in Overlay stinger settings, vMix will now reset the duration and cut times to 0, as the timing from the GT title is used directly.
thanks 15 users thanked admin for this useful post.
doggy on 3/14/2021(UTC), pm on 3/15/2021(UTC), ledavid on 3/15/2021(UTC), Roi on 3/15/2021(UTC), KnightHeart on 3/15/2021(UTC), stigaard on 3/17/2021(UTC), edhorn on 3/20/2021(UTC), KCHSLA on 3/21/2021(UTC), ON.tv Channels on 3/26/2021(UTC), eduardocfs on 3/30/2021(UTC), R_L on 4/12/2021(UTC), sinc747 on 4/22/2021(UTC), davidcl on 4/24/2021(UTC), avsoundguy on 6/15/2021(UTC), jet on 10/11/2021(UTC)
#4 Posted : Friday, March 26, 2021 3:08:03 PM(UTC)
24.0.0.52
* Added support for 100p and 200p frame rates.
* Fix for incorrect animation when transitioning in to a new Title on an Overlay channel while the animation of the previous title was still in progress.
* Fix for Mix input Cut shortcut not always working when using multiple mix inputs at a time.
* Fix for error when loading Instant Replay when Display Mode is set to Legacy in Settings -> Performance. We strongly recommend this be changed
to Auto however, as Legacy has performance issues on modern machines.
* Added Channel parameter support to Scripting
* Running script duration is incorrect when multiple scripts are running at a time.
stigaard on 3/26/2021(UTC), Roi on 3/26/2021(UTC), ON.tv Channels on 3/26/2021(UTC), KnightHeart on 3/27/2021(UTC), raugert on 3/27/2021(UTC), Ezekiel3vs18 on 3/27/2021(UTC), sinc747 on 3/27/2021(UTC), eduardocfs on 3/30/2021(UTC), Chircanu on 3/31/2021(UTC), kurzschuss on 4/7/2021(UTC), R_L on 4/12/2021(UTC), davidcl on 4/24/2021(UTC), emiliovt on 5/27/2021(UTC), avsoundguy on 6/15/2021(UTC), jet on 10/11/2021(UTC)
#5 Posted : Wednesday, April 7, 2021 3:35:07 PM(UTC)
24.0.0.56
* New WebM support including Alpha Channel.
Note: heavily compressed files like WebM use more CPU than larger but lightly compressed formats like MOV.
So WebM support has been added for convenience, but do not expect it to perform better than image sequences and MOV.
* New Audio Gap Handling feature added in Settings - Audio.
Provides alternative option instead of audio "drops" where audio source is slightly slower than the computer.
See the help file for further information:
https://www.vmix.com/help24/Audio.html
* Fix for audio alerts not calculating correctly and may display even if there was audio in the past x seconds.
* Improved vMix Call audio sync slightly
* Frame Rate setting can now be adjusted without unticking Use Streaming Settings in Settings -> External Output, as it is not controlled by streaming settings, only resolution is.
* SRT library was not updating correctly in 24 and was still version 1.4.0. Latest version 1.4.2 now installs correctly.
* Fixed replay showing live previews too early, leading to flicker at end of events playback.
* Fixed SRT outputs not starting up again when restarting vMix due to settings changes
* Fixed preset folder not showing the correct folder on save when opening presets directly by double clicking the files.
thanks 16 users thanked admin for this useful post.
stigaard on 4/7/2021(UTC), pba on 4/7/2021(UTC), Roi on 4/7/2021(UTC), kurzschuss on 4/7/2021(UTC), Chap on 4/8/2021(UTC), YBS on 4/8/2021(UTC), AlanZ on 4/8/2021(UTC), ask on 4/8/2021(UTC), eduardocfs on 4/8/2021(UTC), sinc747 on 4/12/2021(UTC), R_L on 4/12/2021(UTC), jet on 4/13/2021(UTC), raugert on 4/13/2021(UTC), davidcl on 4/24/2021(UTC), emiliovt on 5/27/2021(UTC), avsoundguy on 6/15/2021(UTC)
#6 Posted : Wednesday, April 21, 2021 4:10:04 PM(UTC)
24.0.0.57
* NDI FEIM checkbox was not being saved in a preset
* Going to Previous video in a List input using shortcut or back button would not jump over disabled items in the list
* Web Controller buttons may look incorrect if the name of the shortcut button was long
* Virtual sets would not load the default angle correctly when opened from preset
* Double checks for multiple instances of vMix running, as accidentally double/triple clicking on start bar icon may not have been detected previously.
* Fixed distorted borders when using in NDI inputs not yet connected
thanks 14 users thanked admin for this useful post.
jet on 4/21/2021(UTC), Roi on 4/21/2021(UTC), eduardocfs on 4/21/2021(UTC), ben112 on 4/21/2021(UTC), stigaard on 4/21/2021(UTC), raugert on 4/21/2021(UTC), sinc747 on 4/22/2021(UTC), Simsyuk on 4/22/2021(UTC), ask on 4/22/2021(UTC), davidcl on 4/24/2021(UTC), mobiletonster on 4/26/2021(UTC), emiliovt on 5/27/2021(UTC), avsoundguy on 6/15/2021(UTC), Chap on 6/15/2021(UTC)
#7 Posted : Friday, April 30, 2021 3:57:13 PM(UTC)
24.0.0.58
* Incorrect colour space may have been applied to WebM alpha videos and ProRes 444 videos
* Local scripts were not being removed with Remove button
* Activators for replays 5-8 were not working correctly
* Older GT titles with stray animations may not have played back correctly when removing animations from them
thanks 9 users thanked admin for this useful post.
Chap on 4/30/2021(UTC), ask on 5/2/2021(UTC), raugert on 5/4/2021(UTC), emiliovt on 5/27/2021(UTC), Roi on 6/5/2021(UTC), avsoundguy on 6/15/2021(UTC), eduardocfs on 9/12/2021(UTC), jet on 10/11/2021(UTC), sinc747 on 10/14/2021(UTC)
#8 Posted : Friday, June 4, 2021 12:21:44 PM(UTC)
24.0.0.59
* Updated SRT library to latest 1.4.3. This fixes a crash issue in the library when some versions of VLC attempt to connect
* Added support for "Select Case" in VB.NET scripting
* Instant Replay Export progress bar may not have updated correctly for combined clips
* Instant Replay Export will now encode much faster to MP4 if replay recording is stopped
* Fix for issue where if some replay sources have no audio they would take a long time to export alongside other angles with audio
thanks 12 users thanked admin for this useful post.
doggy on 6/4/2021(UTC), stigaard on 6/4/2021(UTC), eduardocfs on 6/4/2021(UTC), sinc747 on 6/5/2021(UTC), greggibson on 6/5/2021(UTC), Roi on 6/5/2021(UTC), ask on 6/8/2021(UTC), raugert on 6/9/2021(UTC), GLaNarathip on 6/9/2021(UTC), avsoundguy on 6/15/2021(UTC), Chap on 6/15/2021(UTC), jet on 10/11/2021(UTC)
#9 Posted : Friday, June 11, 2021 4:28:33 PM(UTC)
24.0.0.60
* Updated Twitch login for both vMix and vMix Social due to new browser policy on Twitch
* Fixed infinite loop possible when setting Dynamic input to itself
* Fixed TCP API tally showing incorrect numbers for inputs both in output and overlay at same time
* TCP and Web API are now locked down by default with some enhanced security measures.
These prevent a remote web page from accessing the API when opening that web page on the same machine as vMix.
thanks 10 users thanked admin for this useful post.
Simsyuk on 6/11/2021(UTC), stigaard on 6/11/2021(UTC), eduardocfs on 6/11/2021(UTC), Roi on 6/12/2021(UTC), sinc747 on 6/13/2021(UTC), avsoundguy on 6/15/2021(UTC), TDVideoEngineering on 6/15/2021(UTC), Chap on 6/15/2021(UTC), brucedk on 6/16/2021(UTC), jet on 6/19/2021(UTC)
#10 Posted : Monday, June 14, 2021 4:14:12 PM(UTC)
24.0.0.61
* Fixed issue when changing Input Frame Delay, that may cause the input to stop or corrupt memory.
thanks 11 users thanked admin for this useful post.
stigaard on 6/14/2021(UTC), Roi on 6/14/2021(UTC), eduardocfs on 6/14/2021(UTC), GLaNarathip on 6/15/2021(UTC), avsoundguy on 6/15/2021(UTC), TDVideoEngineering on 6/15/2021(UTC), sinc747 on 6/15/2021(UTC), ask on 6/15/2021(UTC), Chap on 6/15/2021(UTC), raugert on 6/16/2021(UTC), jet on 6/19/2021(UTC)
#11 Posted : Thursday, June 17, 2021 7:09:40 PM(UTC)
24.0.0.62
* Fixed issue with YouTube Stream Now login caused by recent security updates.
thanks 8 users thanked admin for this useful post.
eduardocfs on 6/18/2021(UTC), ask on 6/18/2021(UTC), Roi on 6/18/2021(UTC), stigaard on 6/19/2021(UTC), raugert on 6/19/2021(UTC), jet on 6/19/2021(UTC), sinc747 on 6/23/2021(UTC), avsoundguy on 6/29/2021(UTC)
#12 Posted : Sunday, July 4, 2021 5:30:11 PM(UTC)
24.0.0.63
* Fix for missing fonts at end of dropdown list in GT Designer
* Adding warning when enabling Fault Tolerant on recording, as it has a number of limitations that operators should be aware of.
* Fixed vMix AVI in Instant Replay not able to be converted to MOV in vMix Media Converter
* Fixed Select Case in scripting not working if indented/formatted
stigaard on 7/4/2021(UTC), doggy on 7/4/2021(UTC), Chircanu on 7/4/2021(UTC), Roi on 7/4/2021(UTC), Chap on 7/5/2021(UTC), John Barson on 7/5/2021(UTC), ask on 7/5/2021(UTC), monamiga on 7/5/2021(UTC), eduardocfs on 7/5/2021(UTC), dmwkr on 7/5/2021(UTC), ron2210 on 7/5/2021(UTC), damean on 7/7/2021(UTC), raugert on 7/8/2021(UTC), sinc747 on 7/16/2021(UTC), jet on 10/11/2021(UTC), avsoundguy on 11/10/2021(UTC)
#13 Posted : Wednesday, September 8, 2021 5:22:53 PM(UTC)
24.0.0.66
* NEW default Dark Mode for vMix Social Web Interface, link at bottom of vMix Social Web Interface page is available to switch back to light mode if needed.
* NEW Twitter streaming destination. Periscope is now discontinued and replaced with direct Twitter streaming. Users who currently use Periscope/Twitter destination
will need to login again and configure a stream title.
* Support for newer VST3 plugins such as new NDI5 tools
* Fix for duplicated text when loading GT tickers from presets
* Fix for error message opening MultiCorder when a non-supported stream is added to vMix
* Fix for issue where disconnecting PTZ on one Sony VISCA camera disconnects them all
* Improved Tally light support for Sony VISCA over IP cameras
thanks 21 users thanked admin for this useful post.
Roi on 9/8/2021(UTC), doggy on 9/8/2021(UTC), monamiga on 9/8/2021(UTC), eduardocfs on 9/8/2021(UTC), Peter Berglund on 9/8/2021(UTC), joel72004 on 9/8/2021(UTC), m_santana on 9/9/2021(UTC), sinc747 on 9/9/2021(UTC), Chircanu on 9/9/2021(UTC), ask on 9/9/2021(UTC), Simsyuk on 9/10/2021(UTC), ron2210 on 9/13/2021(UTC), raugert on 9/15/2021(UTC), asford on 9/26/2021(UTC), asford ricks on 9/26/2021(UTC), stigaard on 9/27/2021(UTC), ksinnott on 9/28/2021(UTC), mgrayeb on 10/1/2021(UTC), jet on 10/11/2021(UTC), avsoundguy on 11/10/2021(UTC), JW on 12/10/2021(UTC)
#14 Posted : Monday, September 27, 2021 12:43:43 PM(UTC)
24.0.0.70
* Fix for potential audio hiccups during replay transitions at 50p/25p frame rates.
* Fix for ReplayLastEvent shortcut not working correctly
* Fix for wrong angle in replay activators on channel b when in A|B mode
* Fix for incorrect input sometimes displayed in Edit Activator
thanks 7 users thanked admin for this useful post.
eduardocfs on 9/27/2021(UTC), stigaard on 9/27/2021(UTC), ksinnott on 9/28/2021(UTC), JacobLarsson on 9/29/2021(UTC), jet on 10/11/2021(UTC), sinc747 on 10/14/2021(UTC), avsoundguy on 11/10/2021(UTC)
#15 Posted : Monday, September 27, 2021 5:55:55 PM(UTC)
24.0.0.71
* Fixed rare race condition when closing an NDI input connected to NewBlue Titler Live.
May cause spurious clock values to appear.
* Splash screen now 50% sharper
Roi on 9/27/2021(UTC), stigaard on 9/27/2021(UTC), eduardocfs on 9/28/2021(UTC), ksinnott on 9/28/2021(UTC), ask on 9/29/2021(UTC), mgrayeb on 10/1/2021(UTC), jet on 10/11/2021(UTC), sinc747 on 10/14/2021(UTC), avsoundguy on 11/10/2021(UTC)
#16 Posted : Monday, October 11, 2021 5:00:28 PM(UTC)
24.0.0.72
* Replay DUR display now factors in transition time when multiple events selected.
* Replay remaining time now factors in transition times
* ReplaySelectAllEvents would not work properly with subsequent shortcuts
* Fix for SQ and LQ replay quality settings resulting in lower than expected quality after some time
* MultiCorder Timeline filename now matches recording filename format
Roi on 10/11/2021(UTC), stigaard on 10/11/2021(UTC), Chircanu on 10/11/2021(UTC), Peter1000 on 10/11/2021(UTC), jet on 10/11/2021(UTC), eduardocfs on 10/11/2021(UTC), ask on 10/12/2021(UTC), xaver on 10/12/2021(UTC), sinc747 on 10/14/2021(UTC), David_in_Philly on 10/17/2021(UTC), raugert on 10/20/2021(UTC), avsoundguy on 11/10/2021(UTC), corporatejames on 11/27/2021(UTC), JW on 12/10/2021(UTC), QuiapoChurch on 2/6/2022(UTC)
Guest (10)
