Howdy....
I have a very fast Alienware that I use as my main portable vMix system. Quite frankly, for most of what I do, it's overkill and rarely ticks up past 15% CPU.
I'm looking for an economical backup laptop, and came across this Lenovo Legion 5i Pro from Costco. I'm mostly wondering how the RTX3050 would be in this system... Anyone else using a 3050? Would love to hear your results...
What do you think of this build and price?
Lenovo LEGION 5i Pro 16" Gaming Laptop - 11th Gen Intel Core i7-11800H - 165Hz 2560 x 1600 Display - Storm Gray Item 3000600Model 82JF0000US Online Price1,299.99$ Less200.00$- Your Price1,099.99$ Shipping & Handling: $9.99* May be available In-Warehouse at a lower non-delivered price $200 OFF
Features: 11th Gen Intel® Core™ i7-11800H Processor Wi-Fi 6 (2x2/160) Gig+ and Bluetooth® 5.0 NVIDIA® GeForce RTX™ 3050, 4GB 16" LED-backlit Anti glare IPS QHD (2560 x 1600) 165Hz Display
Let me know your thoughts...
Best,
Ben
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
Costco also has the MSI GE76 17" with 3060, i7-11800H, 16GB, 1TB SSD for $1299, ends tomorrow though. The 1080p 144hz screen is not the best (~60% srgb gamut) but we use external displays anyways. Picked one up. Can use a external monitor, can't just replace the gpu in these.
Don't forgot the Allstate $99 warranty adds the third year but also gives years 1-3 accidental damage coverage, no brainer.
Sold out online, my local Costco got a 2nd batch in around the 16th, I picked one up then. Many locations are sold out.
In benchmarks, appears to be outperforming (3dMark) the Alienware X17's with 3060s (hundreds $ more). We have been using Alienware/Dell for over 20 years as well.
I think the 3060 is the better option vs 3050 for vmix. The Lenova does have a better display and perhaps its hinge design is a little more durable but I'd go for the 3060 over the 3050 (suppose it depends on the # of vmix inputs you use), can't upgrade the gpu in the future.
Costco gives you 90 days to try it out, try it or try them both (if MSI still available). Seeing the MSI out of stock does say a lot though.
Joined: 7/16/2021(UTC) Posts: 22  Location: Legnano Thanks: 2 times
Best,
Ben
The Rtx 3050 is one of the worst Nvidia ever done... btw for 1300$ it's a good backup laptop
