richardgatarski
#1 Posted : Wednesday, September 22, 2021 4:52:00 AM(UTC)
richardgatarski
Both with a Shortcut (e.g. D1) and http://127.0.0.1:8088/api/?Function=ChangeCountdown&Input=Timer&SelectedName=Time.Text&Value=00%3A08%3A00
Below one minute (e.g. 00:02:00, and 00:07:00) works fine, but not above seven minutes (e.g. 00:08:00 and 00:10:00)
SetCountdown works slightly better. Besides, I really don't understand the diff Set vs Change ;) But ChangeCountdown will display the time I want without the timer running. That is, I want to set a timer with an API shortcut, get visual feedback of what I have set it to, and then another shortcut to start the countdown.
Any ideas?
Thanks.
#2 Posted : Wednesday, September 22, 2021 5:29:03 AM(UTC)
Seems to work fine here (both)
&Value=01%3A33%3A05
&Value=01:33:05
Believe ChangeCountdown is to change the displayed time ( running or not) setting time remains same as set by SetCountdown
#3 Posted : Wednesday, September 22, 2021 5:34:59 AM(UTC)
BTW
Regarding HTML URL Encoding it seems only the first character after the equal sign is important ( but yeah better safe than sorry )
http://127.0.0.1:8088/api/?Function=SetText&Input=Timer&SelectedName=Description.Text&Value=%2B%3D5
http://127.0.0.1:8088/api/?Function=SetText&Input=Timer&SelectedName=Description.Text&Value=%2B=5
work fine
http://127.0.0.1:8088/api/?Function=SetText&Input=Timer&SelectedName=Description.Text&Value=+=5
Is wrong
richardgatarski
#4 Posted : Wednesday, September 22, 2021 5:41:44 AM(UTC)
richardgatarski
thx Doggy! I think (wild guess) my issue is related to some regional setting in Windows, and how vMix parse the value...
#5 Posted : Wednesday, September 22, 2021 5:51:35 AM(UTC)
a bit like Excel can mess (CSV ; instead of , ) things up due to regional settings ;-)
richardgatarski
#6 Posted : Monday, October 4, 2021 1:57:27 AM(UTC)
richardgatarski
Hmmm doggy,
Whereas SetText works fine, I am trying to get ChangeCountdown working - and this one REALLY annoys me...
To sum up my findings, to me there seems to be a couple of bugs here:
1. The Countdown has to be started before ChangeCountdown has any effect at all.
2. It is not possible to change to a time above the time that was "manually" set before the countdown was started. This is true for hh, mm, and ss respectively. That is, if hh is initially set to 01 one change change it to 02 (with ChangeCountdown).
Adding Timer Centre.gtzip, changing it´s name to just Timer and the following happens.
http://127.0.0.1:8088/api/?Function=ChangeCountdown&Input=Timer&SelectedName=Time.Text&Value=00%3A01%3A00
result, just showing the clock
Then, setting 00:02:00 in the Title Editor and starting the Countdown
result, counting down from 00:00:59
http://127.0.0.1:8088/api/?Function=ChangeCountdown&Input=Timer&SelectedName=Time.Text&Value=00%3A02%3A00
result, counting down from 00:01:59
http://127.0.0.1:8088/api/?Function=ChangeCountdown&Input=Timer&SelectedName=Time.Text&Value=00%3A03%3A00
result, counting down from 00:01:59 (yes 01:59, not 02:59 as excpected
http://127.0.0.1:8088/api/?Function=ChangeCountdown&Input=Timer&SelectedName=Time.Text&Value=00%3A04%3A00
Stopping the clock now shows 00:00:00, then
result, shows 00:01:00
result, shows 00:02:00
Closing the Title, adding and renaming it again and the instead of 00:02:00 set 00:25:00 and start countdown will work for all minuts less than or equal to 00:25:00. Minutes above that are treated as 00:25:00
Please prove me wrong ;)
#7 Posted : Monday, October 4, 2021 2:39:35 AM(UTC)
a quick check
AdjustCountdown:
add/subtract seconds to the running time , blocks to end time if going past the initial set time. With clock not running wil show set time (end)
SetCountdown:
Changes the initial countdown time , when clock running will show time based on new set time with already past time subtracted
To start countdown again from new set time stop countdown first and start again.
ChangeCountdown:
With running clock will restart countdown from the changed time. does not affect the initial set time. if clock not running no effect, next start will be from original set time
thanks 3 users thanked doggy for this useful post.
stigaard on 10/4/2021(UTC), TL68 on 12/13/2022(UTC), Locke on 2/5/2024(UTC)
