hsteppke
#1 Posted : Friday, September 17, 2021 2:36:15 AM(UTC)
hsteppke
Germany
since could of weeks maybe month (id did work month ago for sure ) i can no longer use Waves Plugins like L2 or NS1 and so on.
When i want to add them there is a popup saying the "Could not be initialize Plugin" and the Window below says "AddPlugin OK"
I can see for a little while when i touch the drop down and have touched the Shell the small little waves icon spinning but when i select one and try adding it the error pops up.
YoLan Loudness Meter however does work.
I already tryed fixing waves, unistall all plugins, all fixes in the waves menue. v12 and v11 version of the plugin.
No other user is logged into the machine.
resintalled vMix , reinstalled waves
Any Ideas are more then welcome :)
Holger
P.S. any way to doanload older vmix versions ? just to test like 24.0.0.63 or 24.0.0.46 .47 .48 so version where something has changed regard VST
Narcogen
#2 Posted : Tuesday, September 21, 2021 6:30:23 AM(UTC)
Narcogen
Rank:: Advanced Member
Do the plugins work in any other hosts?
This has happened to me twice already, and both times it was a result of Waves de-authorizing my plugins. Once was because I changed NICs in my PC, and the other time... I'm not really sure.
hsteppke
#3 Posted : Tuesday, September 21, 2021 7:49:30 AM(UTC)
hsteppke
Germany
I did open a Waves Support Ticket and they had a tip for me which fixed it .. basically it re-installs/repairs all required visual c/c++ libraries
Please follow these next steps:
Quit all applications.
Make sure all the latest windows updates are installed.
Go to C:\Program Files\Waves Central\resources\res\external\Redistributables.
Now, go through each folder and run all the Application files, one by one ( Let me know if you're getting any errors). Select the 'Repair' option to repair all of them.
If prompted to restart, you can skip that until you finish all the files.
See if you can load the plugins.
