Systems
Anybody here build a portable Vmix PC in a rack-mountable case?
I'm looking to build a mobile vmix PC, that I can transport in a rolling rack case. It would be great if there was a solution to integrate the screen somehow also, but it would still be acceptable to just house the PC in the case and carry the accessories separately. Would something like this be adequate to build a vmix PC in? showbox speed test
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
I built 2 like this Dell 3930, Cisco SG500X-24p, Symetrix Dante DSP/IO
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
I am currently in process of building over the top rig for a client, it houses a 24" screen, PC, videohub, a bunch of converters, ATEM Mini Extreme, etc. It is a "single unit", just put it on a table, connect power and cameras and you are ready to rock. You can route each input (HDMI or SDI) to any of the 8 inputs for vMix. There are also 4 dedicated outputs from vMix (Outputs 1-4) which any can be SDI or HDMI (Yes, Output 3 and 4 can be SDI as well, not just NDI) and additional you have 2 fullscreen outputs as well, also HDMI or SDI. Dual 4G connections with failover when main WAN goes down, 3 PoE ports, 10 power sockets for other devices, 4 input 4 output audio interface, front panel has 6 USB ports, all kinds of different memory card readers etc. Basically, all you need in one package, but expensive. I have also built laptop-based systems, less power, and connections but more than enough for some. If you are interested, contact me at Mart@voogle.ee
Joined: 8/4/2020(UTC) Posts: 16   Location: Mumbai Thanks: 20 times Was thanked: 4 time(s) in 2 post(s)
Originally Posted by: MartLeib  (Yes, Output 3 and 4 can be SDI as well, not just NDI) Can you please guide how to get vMix Outputs 3 and 4 via SDI? I am using Blackmagic Decklink Duo 2 Thanks in advance
Systems
