Joined: 3/18/2021(UTC) Posts: 46   Location: Tokyo Thanks: 19 times Was thanked: 15 time(s) in 12 post(s)
I developed StreamDeck's native plugin for vMix. It uses TCP API with Shortcut function such as "PreviewInpu", "Stinger1" and so on. This should be helpful if you're using StreamDeck with HTTP Web API insted of official StreamDeck plugin for companion. Also it configure TALLY. https://github.com/Flowi...eck-vmix-plugin/releases
Joined: 9/15/2021(UTC) Posts: 1  Location: Spencerbury
The Stream Deck application loads all the custom plugins it finds when it is started. A set of APIs allows a bidirectional communication between the plugins and the Stream Deck application. This communication is implemented using WebSockets and the messages are exchanged as json data: advanced md
