Joined: 3/30/2020(UTC) Posts: 17   Location: Leran Thanks: 14 times
I have received some recorded footage where the camera was positioned too low and is 'looking upwards' at the talent so the person seems to have a much smaller head than her feet. Is there any way to distort the picture to compensate ? the X/Y/Z adjustments operate on all 4 corners of the frame equally, and I need to make the top wider than the bottom. Rgds Clive
If the X,Y,Z rotation of the input are not enough one can :
if that angle is constant and are able to correct a screenshot to an acceptable result with a image editor one could then use a UVmap in a basic virtual studio that has been modified in the same way as your screenshot ( fhotoshop or Gimp to retain the UV specifics after saving the edit)
Thank you for this. It feels a bit beyond my technical capability but I can see how the principles might be applied. I will have to experiment with this. I am sure that others who are more competent that me will appreciate this advice All good wishes
