nowski
#1 Posted : Wednesday, September 8, 2021 8:23:29 AM(UTC)
nowski
Just looking into a way to integrate more automation into my live production.
I'm looking for a way to use a google sheet to fire a number of different actions, not just titles.
EG, select row, populate lower third, play/load video or web page, fire off a url to post a link to a discord channel with a link to the current topic so that it gets posted in the timed comments using Restream chat bot etc.
As far as I can see the values returned from datasources can only be accessed from Titles inputs.
Would be SO useful to be able to push them into other actions too....
Am I dreaming or just going to have to get into some scripting stuff. Not sure I have enough brain left to learn another programming language.;-)
#2 Posted : Wednesday, September 8, 2021 4:50:29 PM(UTC)
Rank:: Advanced Member
Afraid you are going to have to resort to scripting
Titles are often used as a variable container fed by a data source , they are just not visibly shown in the title display. pulled from the the title (easy) you can use them to your liking in a script from simple to complex
Using external coded apps does n0t limit you to the vMix scripting language of vb.net and can send actions to vMix too.
nowski
#3 Posted : Wednesday, September 8, 2021 10:20:52 PM(UTC)
nowski
Thanks for the help!
Are there any resoucres or examples where datasources are used in this way?I guess its not "the usual"method so searches have been fruitless so far.
#4 Posted : Wednesday, September 8, 2021 11:29:10 PM(UTC)
https://forums.vmix.com/...ng-for-Dummies#post80860
https://forums.vmix.com/...-color-change-using-data
nowski on 9/9/2021(UTC)
Papo
#5 Posted : Thursday, September 9, 2021 5:36:17 AM(UTC)
Papo
Peru
Excuse me that it may not be on the subject, but from what you wrote, I could consult a possibility, having a spreadsheet in google activate a command to vmix ?, in google spreadsheets can be programmed so that when a change in a specific cell a command is sent? I understand that it is programmed in phyton it seems to me, is that possible doggy friend
translated from spanish to english by google
nowski
#6 Posted : Thursday, September 9, 2021 10:59:30 PM(UTC)
nowski
Doggy, thanks Scripting is easier than it seems, certainly for simple tasks.
Was easy to pull values into a titles input then turn them into DynamicValues - I was able to open browser window with URL from datasource using the first example from your links
Papo - thats in interesting idea also run the show from a Google sheet, but worth thinking about the possibilities .What I want to do it select a topic, have it fire a video or URL, then post the link to the chat - Youtube preferable, but I will need to figure out how to turn my URL into a Youtube comment post via the API I think
mavik
#7 Posted : Friday, September 10, 2021 11:40:48 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
@nowski: You can use a QR code in the video to target your audiance to a link or reference. Just as an option.
nowski
#8 Posted : Monday, September 13, 2021 6:18:04 PM(UTC)
nowski
Thanks Mavik, what I'm trying to get to is have 8 topics buttons.
Each time I press one, I get either the web page or the video playing (yet to figure this - but using a datasource with a switch value will be part of it I think), a lower third - easy.
And to post the link to the Youtube or Restream chat automatically.
The 8 topics are taken from a show spreadsheet, each with a link, and or a video, a switch to indicate whether to open a browser or play a video.
For a one man production this will save quite a lot of time and enable the show to be self contained so easy to run locally or from a cloud instance.
N
nowski
#9 Posted : Tuesday, September 14, 2021 1:18:39 AM(UTC)
nowski
Ok so now I'm in the realms of meta scripting - eg:
I use scripts to pull variables from a datasource - check that works fine.
Now I'm finding I want to create dynamic scripts from these variables which would be API.Function("ScriptStartDynamic",Value:="newscript goes here that is a mix of strings and variables")
Is that even possible?
If so, how would I build the string to send from a mix of text and variables created from the datasource to send to the ScriptStartDynamic API call?
Nick
#10 Posted : Tuesday, September 14, 2021 2:06:36 AM(UTC)
how would I build the string to send from a mix of text and variables ?
https://www.dotnetperls.com/string-concat-vbnet
Additionally
Code:
Dim value1 As String = "Visual"
Dim value3 as string = value1 + "Basic"
Console.WriteLine(value3)
nowski
#11 Posted : Tuesday, September 14, 2021 8:11:19 AM(UTC)
nowski
Excellent, thanks Doggy,
Is this a wise/acceptable method for creating dynamic scripts?
I want to be able to make the vmix doc portable.
Also, I cant see a way to create shortcuts via API.
Was thinking that I could build those from the number of topics.
Eg set SetShortcut, value=Function, trigger=MIDI note or whatever
But I'm not sure that is possible?
Nick
#12 Posted : Tuesday, September 14, 2021 8:22:47 AM(UTC)
Is there one in this list ? https://www.vmix.com/hel...utFunctionReference.html
