DynamicValues inside SetMultiViewOverlay not working as expected
Joined: 4/14/2020(UTC) Posts: 17  Location: Dallas, TX Thanks: 5 times
I am trying to use Companion to SetMultiViewOverlay using DynamicInput and DynamicValues. DynamicInputs work great, but DynamicValues do not appear work at all. What I am trying to do: In Companion, select a Regular Button and select SetMultiViewOverlay. MultiView Input = 2UP Layer = DynamicValue1 Input To Use on Layer = DynamicInput1
If I change the second value (Layer) to a number such as 2 or 3, the above works just great. But I want to be able to Select a value button on a Companion number pad, Select a DynamicInput and place it in any layer I want.
Is this a current limitation of DynamicValues?
DynamicValues appear to work just fine in other areas, but not in the SetMultiViewOverlay.
Thanks!
Originally Posted by: cchhita  I am trying to use Companion to SetMultiViewOverlay using DynamicInput and DynamicValues. DynamicInputs work great, but DynamicValues do not appear work at all. What I am trying to do: In Companion, select a Regular Button and select SetMultiViewOverlay. MultiView Input = 2UP Layer = DynamicValue1 Input To Use on Layer = DynamicInput1
Thanks!
SetMultiViewOverlay ( or the new SetLayer) demands for a value a "index,input" string and one has to set the Dynamic value accordingly!
Thanks Doggy! I have found that using the Built-in Companion Action does not work (Like this) https://imgur.com/a/myJf0qnBut using the RUN action works as you mention above: SetMultiViewOverlay Value=DynamicValue1&Input=2UP Where DynamicValue1 can be an Index,Input combo such as 2,3 OR 2,DynamicInput1 Appreciate the help
Originally Posted by: cchhita  SetMultiViewOverlay Value=DynamicValue1&Input=2UP Where DynamicValue1 can be an Index,Input combo such as 2,3 OR 2,DynamicInput1
A General reminder ! One sets the DynamicInputx and DynamicValuex but calls it in a function with Dynamicx ( = same for both the input and the value within a function) Some interesting tricks with the use of dynamic in scripts for easy selection in multiviews (@28) ?t=1703
