Joined: 9/4/2021(UTC) Posts: 3  Location: Oswego Thanks: 1 times
Hi, folks. I am setting up vMix for our church to stream our services. The Facebook Live stream drops within only a couple of minutes. I AM able to use vMix to produce the content with PowerPoint and a PTZ camera and stream using OBS that captures vMix the output screen. This configuration works very well, but is clumsy and I want to get vMix to do the streaming too. It seems that if I can run vMix and OBS and successfully stream then vMix should be able to do it alone. As I watch the vMix stream, the CPU and GPU percentages are nominal but the total CPU is very high. Watching the GPU performance shows a constant flow until it sharply pegs and then drops to zero. Stream is lost. Any ideas? Thanks.
Hardware: AMD Ryzen 3 CPU 3.5 GHz Radeon Vega Graphics GeForce 2GB 8 GB DDR4 (PC4-19200) 480 GB Solid State Hard Drive (Windows Hard Drive for performance) Internal DVD Writer 22X Onboard 10/100/1000 Gigabit LAN Onboard 8 Channel Audio Windows 10 Professional 64bit GeForce Graphics Card
Network: Spectrum Cable 100/10. There are no drops shown by Spectrum.
Your problem is most likely linked to your use of a Radeon Vega GPU in your system. NVIDIA cards are recommended. From the vMix Knowledge Base Quote:Avoid: Intel Integrated Graphics, AMD Radeon Graphics, NVIDIA "MX" series graphics on Laptops. NVIDIA Quadro cards with 3 digit model numbers (such as P600 or P520)
https://www.vmix.com/knowledgeba...-a-laptop-or-pc-for-vmixIf you have a spare NVIDIA card that meets vMix specs, try using that and see if that solves the issue.
