Feature Requests
Production Clock set via scripting
Would be useful to be able to set the production clock start time via the API.
This way I could set a timecode start time via an application.
Joined: 10/28/2014(UTC) Posts: 16 Location: Rotherham, UK
Thanks: 34 times Was thanked: 6 time(s) in 4 post(s)
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
+1 - We occasionally use LTC or MTC to control our lighting system, being able to import and see the timecode values as the production clock on vMix would be great
Joined: 8/31/2016(UTC) Posts: 15   Location: Little Rock, AR Thanks: 4 times
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Rank:: Advanced Member
Joined: 7/10/2020(UTC) Posts: 35   Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Joined: 12/27/2012(UTC) Posts: 5,522  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: jponsford  Would be useful to be able to set the production clock start time via the API.
This way I could set a timecode start time via an application. Script - own clock
Originally Posted by: doggy  Originally Posted by: jponsford  Would be useful to be able to set the production clock start time via the API.
This way I could set a timecode start time via an application. Script - own clock It's possible and easy to build it, but if you want to update it every second you have to send a TCP command each time. So it will increase data transmission to VMIX, and this can create unnecessary load and delays or even a vMix crash. A start/stop/set is safer with internal vMix clock.
Joined: 2/14/2018(UTC) Posts: 11 Location: Philippines
Joined: 3/23/2020(UTC) Posts: 139  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
Feature Requests
