greggibson
#1 Posted : Friday, September 3, 2021 12:08:32 PM(UTC)
greggibson
Was thanked: 25 time(s) in 17 post(s)
Could we please get a way to increment or decrement audio volume on an input using the API set amount? That way we could use shortcut keys to increase or decrease input volume. Specifically thinking Companion/StreamDeck buttons using dynamic variables to select an input to adjust.
Something like
AdjustVolume&Value=2&Input=Dynamic1
For example would increase volume in 2db increments each button press.
Or
AdjustVolume&Value=-5&Input=Dynamic1
Would decrease volume 5db each button press.
Would be nice to have this for GAIN as well.
If this exists I'm happy to listen but seems a logical request. Please give it your +1!
Greg
thanks 2 users thanked greggibson for this useful post.
SpeakeasyAV on 9/3/2021(UTC), LelandBest on 9/3/2021(UTC)
cchhita
#2 Posted : Friday, September 3, 2021 12:10:52 PM(UTC)
cchhita
+1 on this request!
You can increment using GT Title for Scoreboards, so having the same syntax as that would be great!
mgrayeb
#3 Posted : Friday, September 3, 2021 12:19:18 PM(UTC)
mgrayeb
+1
LelandBest
#4 Posted : Friday, September 3, 2021 12:55:18 PM(UTC)
LelandBest
+1
jwidgren
#5 Posted : Friday, September 3, 2021 12:57:47 PM(UTC)
jwidgren
Originally Posted by: greggibson Go to Quoted Post
Could we please get a way to increment or decrement audio volume on an input using the API? Perhaps in 1db, 5db and 10db increments? That way we could use shortcut keys to increase or decrease input volume. Specifically thinking Companion/StreamDeck buttons using dynamic variables to select an input to adjust.
Greg
+1. A definite +1 on this request
George E. Kennedy, Jr.
#6 Posted : Friday, September 3, 2021 1:35:37 PM(UTC)
+1
Guycochran
#7 Posted : Friday, September 3, 2021 1:41:40 PM(UTC)
Guycochran
stigaard
#8 Posted : Friday, September 3, 2021 2:40:50 PM(UTC)
stigaard
Denmark
+1
#9 Posted : Friday, September 3, 2021 3:55:43 PM(UTC)
Greg
Does function Setvolume, Input:Dynamic1 or number , Value: +=5 and -=5 or so not work ? (unless i misunderstand the request)
john-at-heretorecord
#10 Posted : Friday, September 3, 2021 6:48:45 PM(UTC)
Sweden
Was thanked: 6 time(s) in 3 post(s)
+1
thanks 1 user thanked john-at-heretorecord for this useful post.
greggibson on 9/3/2021(UTC)
vika
#11 Posted : Friday, September 3, 2021 6:57:17 PM(UTC)
vika
+1
thanks 1 user thanked vika for this useful post.
#12 Posted : Friday, September 3, 2021 7:13:10 PM(UTC)
Who says it doesn't ?
cchhita
#13 Posted : Friday, September 3, 2021 10:38:38 PM(UTC)
cchhita
Unless I am doing something wrong, it does not work for me.
It appears that SetVolume, Input: Dynamic1, +=5 works inside VMIX Shortcuts, but on a companion button it does not seem to work (using the API).
Example:
This does not work: SetVolume Value+=5&Input=DynamicInput1
This does: SetVolume Value=5&Input=DynamicInput1
greggibson
#14 Posted : Friday, September 3, 2021 11:40:03 PM(UTC)
greggibson
Greg
It works as an internal vMix Shortcut but doesn't seem to work as an API call. Can you clarify syntax for an API call? I'd be happy if this would work.
SetVolume&Value=+=5&Input=1 doesn't work.
This doesn't work for GAIN as a shortcut or an API call.
Thanks Guy!
greg
#15 Posted : Saturday, September 4, 2021 1:04:01 AM(UTC)
Greg
Thanks Guy!
greg
in scripting
Code:
API.Function("SetVolume",Input:="3",Value:="-=5")
API.Function("SetVolume",Input:="3",Value:="+=5")
Web
Code:
Function=SetVolume&Input=3&Value=%2D%3D5
Function=SetVolume&Input=3&Value=%2B%3D5
We rarely use a shortcut on the streamdeck with vMix . Find it more flexible to use the website button and do a httprequest . (not stuck to one pc/streamdeck combination setup)
http://127.0.0.1:8088/api/?Function=SetVolume&Input=3&Value=%2D%3D5
http://127.0.0.1:8088/api/?Function=SetVolume&Input=3&Value=%2B%3D5
(or paste directly in Browser)
%2B is Plus sign
%2D is minus sign
%3D is the equals sign
thanks 3 users thanked doggy for this useful post.
stigaard on 9/4/2021(UTC), cchhita on 9/4/2021(UTC), monamiga on 9/5/2025(UTC)
clafarge
#16 Posted : Saturday, September 4, 2021 1:39:48 AM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
+1 ... or possibly a AdjustVolume that takes a positive or negative integer to adjust the current value. ("Set" to set a value, Adjust to adjust the current value by the provided delta.
#17 Posted : Saturday, September 4, 2021 2:20:33 AM(UTC)
For GAIN (FR was about VOLUME !) one will have to call a script with the shortcut
greggibson
#18 Posted : Saturday, September 4, 2021 4:13:24 AM(UTC)
greggibson
Guy thanks so much for all the great info. There are definitely some workarounds here, but I think the workarounds underscore the need for a few basic API calls like AdjustVolume and AdjustGain.
You are the master of vMix scripting no doubt!
Please give my request your +1.
greg
#19 Posted : Saturday, September 4, 2021 4:41:52 AM(UTC)
greg
+1
But let us embrace the fact that vMix allows one to make workarounds until requests are granted or for specific custom personal usages.
greggibson
#20 Posted : Saturday, September 4, 2021 5:49:41 AM(UTC)
greggibson
Guy - Absolutely, thanks again for a solution I can use right now.
greg
Guest (17)
