Joined: 9/2/2020(UTC) Posts: 2  Location: Zagreb Thanks: 1 times
Please help me. How to change default transition on play list? Now is "CUT", but I want fade. I have many items in my play list, and it's complicated to change every entry one by one to fade transition.
Bojan
Originally Posted by: BojanVOX  Please help me. How to change default transition on play list? Now is "CUT", but I want fade. I have many items in my play list, and it's complicated to change every entry one by one to fade transition.
Bojan There is no change default option but : Save your project as a preset, open preset file with a texteditor and search and replace "Cut" with "Fade" , save preset file and start vMix with it If you search the file first for "PlayLists" below will be all the playlist entries
