dalehudson
#1 Posted : Sunday, August 29, 2021 11:44:05 PM(UTC)
dalehudson
Hello everyone,
I want to ask how to change the color of a button to red on Elgato Sream Deck when a transition is in progress and turn it green when it's over? Does anyone know how?
Please show me, thank you!!!
#2 Posted : Monday, August 30, 2021 12:29:15 AM(UTC)
Originally Posted by: dalehudson Go to Quoted Post
Hello everyone,
Are your transitions so long that is is in fact important to indicate that ?
Only way i can think of is to check if the input nr in the output has changed when the transition has been initiated using a shortcut that in turn also starts a script to instruct ( if possible) to change a button color (image).
Theoretically
nicholson84
#3 Posted : Thursday, September 2, 2021 6:56:47 PM(UTC)
nicholson84
Hello everyone,
My Gift Card Site
Connect Stream Deck directly to a USB port on your PC or Mac – do not use a USB hub. Launch the app to customize Stream Deck. Drag action from the right panel and drop them onto your desired keys on the left. Configure your actions and personalize keys with custom icons.
