mjehnichen
#1 Posted : Wednesday, August 25, 2021 3:49:06 AM(UTC)
mjehnichen
Germany
when a input becomes "Preview" it shall trigger another event (e.g. Tally green on a non NDI camera via CGI-Script via browswer reload).
thanks
martin
mavik
#2 Posted : Tuesday, September 7, 2021 1:19:04 AM(UTC)
mavik
Just open http://127.0.0.1:8088/api/ and check the preview section. You will get the input number that is on preview. To set it use http://127.0.0.1:8088/api/?function=previewinput&input=1
doggy on 9/7/2021(UTC)
mjehnichen
#3 Posted : Sunday, October 3, 2021 2:13:13 AM(UTC)
mjehnichen
Germany
Hi Mavik, thanks for your help but either i did not understand the answer or maybe i did not pose the question right.
I want to trigger an event when an input becomes preview. For example: if input1 goes into preview it shall reload browser input2 with an api call to turn on the green LED on my Panasonic PTZ-cam.
How can i achieve this?
Within VMIX there are only triggers for "on transition in" etc. but not for "becomes preview".
#4 Posted : Sunday, October 3, 2021 3:39:11 AM(UTC)
What Mavik is saying is one can set an input into preview with http://127.0.0.1:8088/api/?function=previewinput&input=1 ( or using a shortcut) and combine that with other actions (simulating a trigger)
Reading the API XML one can check which input is in preview. A script can do that and act upon this for giving more commands
