A problem in a Vmix recording
Hello, I'm working with the Vmix pro 23.0.0.68 version. I'm using a video source and a graphic title and 2 more graphic layers(breathing background and windows template) - total of 4 layers. During the live stream i'm recording the Vmix output. The outcome is a damaged file. It is a broken video. not fluent video. Obviously not something that i can work with or give to a client. Here is 3 examples of this vudeo file: Does anyone have an idea what is the cause of the problem & how to solve it? Dori
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
You should experiment with different codecs and recording settings until you find a working one. And buying vMIX and getting the latest version might help too.
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Settings --> Recording --> Recording Memory Buffer might help with this.
That the audio isn't skipping too makes me think there's something else at play, but that's worth a shot.
Joined: 5/19/2021(UTC) Posts: 17  Was thanked: 1 time(s) in 1 post(s)
Looks like you had the “fault tolerant” box checked on mp4? If so that’s your problem and it can’t be fixed on the existing files. That “feature” is a complete and total disaster with absolutely no useful purpose and never should have been released. It might as well be a box that says “check this box for extra safety” but in reality it just screws up all your recordings every single time. They need to copy what OBS did to get “fault tolerant” mp4 recordings.
