MarkNF82
#1 Posted : Wednesday, August 18, 2021 11:48:00 PM(UTC)
MarkNF82
Canada
Was thanked: 6 time(s) in 4 post(s)
While using the "Merge" transition from full screen to layers/multiview, if any inputs have borders, they are cut off during the transition, then cut back on once transition is complete. However when transitioning in the other direction, the border stays on until the transition is completed to full screen, however the border cuts off when complete. Obviously the border can follow the input as in one direction it stays with it, but not the other direction. I suspect this is because full screen inputs cannot have borders.
One thing just noticed, any sources that are cropped with borders, the borders cut off during the transition then cut back on when completed in both directions, making for a very ugly transition.
Requesting this feature be adjusted so that the border follows the input in either transition and fades instead of cuts off when completely full screen input. Very useful transition, but needs adjusting.
