VBscript to export replay events
Anyone have replay events exporting via VBscript ?
I have a script that creates replay events automatically whenever a team score (by simply watching the score and if score increases, script marks a replay event and labels it with the team name).
However if I try to use ExportLastReplayEvent, it doesn't work, or it only works the first time (and I've tried several methods of invoking it/with delays/loops/etc).
Any ideas ?
What's the code for it you have ? do you have the same problem using a direct shortcut (i seem to as in have to press the key a few times) ?
Code below. If I pop a API.Function("ReplayExportLastEvent") in after the ReplayMark, its a no go. If pop it in a seperate script and trigger that after the ReplayMark, still either no go or only works in the first instance. And using shortcut, same issue, the result isn't consistent. Seems like a possible bug? Code:dim hometeam as string = Input.Find("gameinformation").Text("HomeTeam.Text")
dim awayteam as string = Input.Find("gameinformation").Text("AwayTeam.Text")
dim keepscore1 as string = Input.Find("scorebug").Text("homepoints.Text")
dim keepscore2 as string = Input.Find("scorebug").Text("awaypoints.Text")
dim awayscore as string = Input.Find("scorebug").Text("awaypoints.Text")
dim homescore as string = Input.Find("scorebug").Text("homepoints.Text")
Do While True
awayscore = Input.Find("scorebug").Text("awaypoints.Text")
homescore = Input.Find("scorebug").Text("homepoints.Text")
If NOT ( keepscore1 = homescore ) Then
API.Function("ReplayMarkInOutLive", Value:="7")
API.Function("ReplaySetLastEventText", Value:=hometeam)
End If
If NOT ( keepscore2 = awayscore ) Then
API.Function("ReplaySetLastEventText", Value:=awayteam)
End If
sleep(1000)
keepscore1 = Input.Find("scorebug").Text("homepoints.Text")
keepscore2 = Input.Find("scorebug").Text("awaypoints.Text")
sleep(1000)
Loop
