Unexpectedly Recording Multiview
The Record function is configured for "Output1", but vMix is recording the Multiview and not the contents of the Output window. What would cause this behavior?
I have successfully recorded the program output before, but for some reason I an seeing the Multiview in the recorded file.
Thanks in advance,
--Rob
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Check what your outputs are set for (settings- Outputs)
Originally Posted by: doggy  Check what your outputs are set for (settings- Outputs) That is probably it, but I will check when I am back over at the church. I recently created an SRT multi-view output and I bet I set it to Output-1. --Rob
