jurijus01
#1 Posted : Sunday, August 8, 2021 11:20:16 PM(UTC)
jurijus01
Hello Vmix users!
Got a trial task from potential employer - a mock virtual event. Know how to do most of it, but here is what I'm stuck with.
When the event begins, 2 intro VTs are played simultaneously - one for main site streaming output (Output1), one for social site streaming output (Output2). The VTs are equal in length, but have different content accordingly. Main VT is input 1, social VT is input 2
I have set up 2 outputs for same program for each stream, but do realize that for this intro moment social site streaming out needs to play social VT and on completion the programs becomes the same for both streams.
So I set up 2 triggers on input1 (Main VT)
1) onTransitionIn, SetOutput2, Input2
2) onTransitionIn, Play, Input2.
Now here comes the problem. OnCompletion of the VT can't SetOutput2 back to program output. There is no such entry in the drop down menu of what I can switch to. And, Vmix has a weird way of naming what is known is "Program" just an "Output", making it even more confusing.
Can't make sense of those text input fields either when setting up the trigger. One of them has zero in it, another one has nothing in it and under it says "Output, Preview, Multiview, Input".
Any help appreciated.
Yuri prob.png (10kb) downloaded 0 time(s).
richardgatarski
#2 Posted : Monday, August 9, 2021 12:34:44 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
I beleive Outpit is called Active (for historical resons)
