Systems
AMD Ryzen 5 4600H / NVIDIA GTX 1650 vMix Perfomance?
Joined: 7/10/2020(UTC) Posts: 35   Thanks: 16 times Was thanked: 4 time(s) in 3 post(s)
A friend ask me for a "lite" streaming laptop. He's needs is 2 x 1080p inputs, 2-3 NDI inputs and few GT Graphics. I found a Lenovo laptop with AMD Ryzen 5 4600H / NVIDIA GTX 1650.
Do you think that it will work flawless?
Does it worth it to buy the same laptop with Intel Core i7-10750H?
Does latest versions of vMIX fully support AMD Ryzen because I read old posts I am confused?
Thank you in advance
@ tsioukas
Earlier AMD CPU releases lacked the AVX instruction support required for effective vMix operation. With the 3000 series CPUs (4000 on laptops), appropriate AVX support was added making them suitable for use with vMix.
Ice thank you for this answer, from what I read I understood that something changed, but I didn't know what. Unfortunately, I don't use AMD CPUs for my systems because I need thunderbolt support for more professional capture (USB lags on that)
Systems
