Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
First of all, congratulations for this program. Really well done!
My propose was to use at as a standalone app on several computers to really easy control of cameras, if there were this features I believe it would help:
-Settings > Options: Check box to automatically open the latest loaded preset or load from a selected item in a list
-Settings > Display: Fullscreen mode for the main application
-Settings > Options: When click on the input, make it as the output (Why? Because the buttons for cut and quick play are small for a touchscreen, if there was a way to make it larger this option wasn't needed)
Note: also on Windows 8 "On top" doesn't seem to do the expected, I can open as many windows as I want and be at the top of vmix
Also for multiple user use would be useful to have an unlock password for the lock mode.
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Quote:Settings > Options: Check box to automatically open the latest loaded preset or load from a selected item in a list I agree, this would be very useful. Quote:-Settings > Display: Fullscreen mode for the main application Is Start Fullscreen and Start Maximised already available in the Settings/Options menu not enough? Quote:-Settings > Options: When click on the input, make it as the output (Why? Because the buttons for cut and quick play are small for a touchscreen, if there was a way to make it larger this option wasn't needed)
Already asked for in some other topics
