tfrechette
#1 Posted : Friday, July 30, 2021 2:51:42 AM(UTC)
tfrechette
This is for a live church service.
Pianist is sick so playing mp4 song files on vmix. Audio output cable from PC running vmix into an input channel on Presonus mixer. Mixing in live singers with the mp4 song track. This works fine at church.
Would like to take the mixed audio output from the mixer into vmix to stream. Can't do this using the vmix master bus as that is a feedback loop. Is there a way to use one of the other audio buses to make this work?
For example can I send the mp4 audio to Bus A and then route Bus A out of the PC? Or can the audio input from the mixer be routed to a different bus and then stream that bus instead of the master audio bus?
Any other ideas?
Thanks so much!
cutter07
#2 Posted : Friday, July 30, 2021 9:33:47 PM(UTC)
cutter07
Audio from Mixer to Master and all other inputs (mp4, ect.) to Bus A and not Master.
Bus A back to Mixer input.
cutter07
#3 Posted : Friday, July 30, 2021 9:49:17 PM(UTC)
cutter07
tfrechette
#4 Posted : Friday, July 30, 2021 10:32:01 PM(UTC)
tfrechette
Thanks. I will give it a try.
