sbpromotion
#1 Posted : Tuesday, May 13, 2014 4:43:15 PM(UTC)
sbpromotion
By an Atem Television Studio about one year and was still using vMix as an input in the Atem (for incrustations for example).
Wanted to inverse the processus (for have a plan B for streaming), so I by an audio video capture card (keep the video via output prog hdmi from atem come in computer via this card).
Matérial :
1 Atem Television Studio
Cameras running 1980 X 1080, 50i
1 ExpressCard HDMI Audio Video Caputre Card - 1080p, Startech.com
1 Sony Vaio VPCF1, Windows 7 Edition Familiale Premium, 2009
Processor Intel Core i5 CPU M460 2.53 Ghz
RAM 4 Go
64 bits
Streaming via Dailymotion plateform with official account
vMix 8.0.0.56 - :( - HD Edition
A/ First, want to upgrade my version. Can someone confirm that is with this option ?
B/ Here is my problem while streaming (sorry, didn't success in include directy image)
1/ Atem go to ExpressCard go to Flash Media Live Encoder : input 1920 X 1080, output 640 x 360. The result is ok on Dailymotion.
Setting on FMLE : link
Results on Dailymotion : link
2/ Atem go to ExpressCard go to vMix go to Flash Media Live Encoder : same configuration on FlashMediaLive Encoder but the result is two band up and down the image on Dailymotion. Don't understand were I have to modify settings on vMix ?
The difference between the two (with vMix and with FME direct) : link
The setting choose on vMix : link
Image on vMix windows : link
Thanks for all, have a nice day.
Christophe
Egriswold
#2 Posted : Wednesday, May 14, 2014 10:23:10 AM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
sbpromotion,
My suggestions, if your going to stream at such low resolution and bit rate I would recommend setting cameras at 1280x720p and raising the bit rate to 2000kbps if at all possible.
Even if you cant raise the bit rate to much more the 1280x720p will make a huge difference by not needing deinterlacing.
Best of luck
thanks 1 user thanked Egriswold for this useful post.
sbpromotion on 5/15/2014(UTC)
coskel22
#3 Posted : Friday, May 16, 2014 6:45:33 PM(UTC)
coskel22
Thanks Given:
Even setting it to 800 kbps (if its just talking heads with no motion) will make a HUGE difference in quality.
sbpromotion
#4 Posted : Saturday, May 17, 2014 2:52:33 AM(UTC)
sbpromotion
Hi Egriswold and Coskel22,
Thanks for answers and advices. Will try to use it in the future.
My huge problem is where I stream (boccedrome with adsl connexion), the connexion I find often didn't go much more than
1 Mbps (welcome in France :).
With 4G, hope it will change the done soon but my live often go a very long time (till 10 hours sometimes) so I am limited with data exhange too (20 Go per month with my operator, streaming quasi each week).
But will make some tests with advices as soon as I can.
Chris
