Higher render times if vMix application on foreground?
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Has anyone else encountered an issue, where render time is higher when vMix is the active application? Conversely, having vMix running normally while having any window (e.g. Windows Explorer) on the foreground, in any window size, render times drop considerably?
I'm having an ongoing setup where the render times hover consistently between 20-35 ms with vMix on foreground and 11-19 ms with Explorer window in front.
System information: vMix 4K 24.0.0.62, 1080p50 project Windows 10 Core i7 8750H (edit 9750H) RTX2060
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Are you running something else on te PCI bus except the GPU. NVMe SSD Capture card ....?
If, it might be that the PCI lanes get in conflict. The 8th gen i7 is 16 lane if I'm not wrong. The 16 lanes is full with your GPU already.
Yes, I'm using external Thunderbolt enclosure with Blackmagic Decklink Duo (1st gen) and Blackmagic Intensity Pro (1st gen).
System disk is NVMe SSD.
I had a typo in CPU model (it's i7 9750H).
To me it sounds strange that opening Notepad or any other window to foreground would have an effect on PCI lane or other low-level hardware functions, leading to substantially different render times.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
It may be due to integrated graphics. It is quite simple to find out, connect an external display, preferably using DisplayPort since it is usually connected straight to a dedicated GPU, HDMI may be connected through integrated graphics. Now if you move your vMix window to your external monitor, does the render time go lower? Also, does vMix state that you are running on RTX 2060? (Settings -> Performance)
Originally Posted by: jip  Yes, I'm using external Thunderbolt enclosure with Blackmagic Decklink Duo (1st gen) and Blackmagic Intensity Pro (1st gen).
I can highly recommend checking your system and pay attention to the components. It may have all the IO ports but it does not mean that all of this is getting full bandwidth connection inside the mobo. I'm running a relatively old system with a E5-2630v4 and a P2200. My system is always relaxed so far.
