Joined: 8/21/2019(UTC) Posts: 67   Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
I've been using Waves plugins with Vmix for awhile now, but starting this week, they've started failing.
Plugins I'd already added to sources no longer display, and attempting to add a plugin, no plugins display as available under the WaveShell menu.
Did any recent update to Vmix cause issues for users with Waves audio plugins?
Check with Waves central:
Are your Waves licences still valid? ("Free" licences are typically tied to a valid update plan.)
The activation is tied to the Mac address of the first network card Waves find in the PC, any change there?
My licenses all appear to be valid. In Waves Central, they say they are tied to "Local Disk C".
I have installed a new NIC. Do I have to Recover my licenses in order to re-activate them on the new NIC? Waves seems to say I can only do this once a year.
If you can put the old NIC back you will be able (in Waves central) to return the licence to the cloud. Moving a licence back and forth between the cloud and any PC can be done anytime for free.
Otherwise, you need to "recover" the license (once per year per licence).
