Hide Overlay at end of Data Source
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
I have a data source that will typically have 4 or 5 entries for a show. I plan to trigger it with auto-next enabled and loop disabled. Is there any way to use scripting or a trigger to automatically transition out the overlay once the data source reaches the last entry?
Originally Posted by: cgarwood  I have a data source that will typically have 4 or 5 entries for a show. I plan to trigger it with auto-next enabled and loop disabled. Is there any way to use scripting or a trigger to automatically transition out the overlay once the data source reaches the last entry? Scripting: Let the script advance the datasource and check if data is same as previous or catch error (=end of list) . if so then transition out.
