Feature Requests
Move layers in a MultiView Input
To be able to move a layer up/down amongst the other layers. Sure, it's easy to swap two layers using the drop down selection, but the position settings remain (not following the new selection).
 1 user thanked richardgatarski for this useful post.
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
David, this was implemented in v23 (I believe). So, no reason to +1. Just drag the Layer up or down :)
Joined: 9/22/2020(UTC) Posts: 45  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
A bit a hidden function, you have to click and hold on the number of the layer, than drag on top of the number where you want to move the layers to. they will inter-change :)
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Howlswolf  A bit a hidden function, you have to click and hold on the number of the layer, than drag on top of the number where you want to move the layers to. they will inter-change :) Not to forget the shortcut functions ( also usable in a script)
Feature Requests
