Joined: 9/5/2020(UTC) Posts: 38  Location: brisbane Thanks: 2 times
I am using a data source shortcut to scroll through team names to fill the Home and Away teams names on a scoreboard.
i am using DataSourceNextRow.
When it gets to the last row in the data source column, hitting the button does nothing. Loop is ticked on the data source.
Would I need to program a second shortcut with DataSourcePrevRow to scroll back up through the rows, or is there a way it can start from the top again when I get to the bottom of the spreadsheet column. I thought having loop checked would do this but sadly not. Ideally I just want one hot key to cycle through all the teams till i find the one i need.
- Loop is related to the Auto Next option
- There is a DataSourceSelectRow function/shortcut that can be used to jump to the top of the list . Could also be used in a script that checks if the last row has been reached (no change in data) and jump to top.
- If you really want to quickly go through a list to check or select , leave the data source window open and use the shortcuts or mouse (my prefered)
