Joined: 4/21/2021(UTC) Posts: 10  Location: Moscow Was thanked: 1 time(s) in 1 post(s)
Hello, Is it possible with the help of some utility to calculate the exact time that will come at the end of the videolist? Despite the fact that the start time of the playlist will always be different. Thank you!
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: KTVChannel  Hello, Is it possible with the help of some utility to calculate the exact time that will come at the end of the videolist? Despite the fact that the start time of the playlist will always be different. Thank you! Yes if that utility ( or script) checks in the location folder of the individual items , grabs its duration, tally them all and calculate it with a starting time Or loop through the list in the background and get the duration of each individual item from the API XML and tally/calculate How exact ? no idea how exact the duration data of a file is displayed
Joined: 6/3/2021(UTC) Posts: 12   Location: Douala Thanks: 2 times Was thanked: 7 time(s) in 4 post(s)
Originally Posted by: KTVChannel  Hello, Is it possible with the help of some utility to calculate the exact time that will come at the end of the videolist? Despite the fact that the start time of the playlist will always be different. Thank you! Why using a tool for that? Because the overall time of a playlist is written on vMix preview window. When you click on the playlist you can see the overall time of the playlist. Just add that time to the time when you decide to start to play your playlist. I think I missed something. What is your exact end goal?
