	Feature Requests
	Inverse program preview option multiview
                Add the functionality of being able to inverse (program at left or right) the program and preview in the multiview window.  also the possibility of putting something other than preview and program in the first 2 windows |
 Thanks: 77 timesWas thanked: 32 time(s) in 31 post(s)
                That is crazy...only app that has the reverse id VJDirecter 2, and it is the most confusing thing ever...All switching apps goes Left to Right...I hope vMix programmers will never consider such....What I hope they will do, is make the Preview window adaptable to place scripts, or something else ...  |
 Joined: 10/6/2020(UTC) Posts: 98 Was thanked: 21 time(s) in 21 post(s)
                I always worked with a left-to-right workflow, but I was chatting to a colleague who does a lot of sporting events about this after he asked me which way I wanted the multiview set. Apparently in outside broadcast trucks, the vision engineer is usually sat to the right of the director, so they set their video switchers to PGM-PRW, and a lot of video switchers allow this to be changed because of this. So it's not as crazy as it sounds.  |
 Joined: 12/16/2018(UTC) Posts: 69  Location: Newfoundland & LabradorThanks: 1 timesWas thanked: 6 time(s) in 4 post(s)
                I do like the idea of being able to put anything other than Preview/Program in the first two windows. I built an automated vMix setup that I was hoping to use the quad split for, but had to re-create one in layers to give me what I wanted.
 Also, I wish they would stop calling the layers "multiview". It's very confusing when software uses the same term for multiple things.
	Feature Requests
