EpicVisionZone
#1 Posted : Friday, March 19, 2021 10:47:10 AM(UTC)
EpicVisionZone
Is it possible to add the following into vMix as a Shortcut. I am aware of using DataSources but I think this would be useful.
Old Method: Right Click on Input, Select Title Editor
Proposed Shortcut(s): One Shortcut that select the Input, Right Clicks to open the Title Editor. To be used via Stream Deck.
In cases where perhaps only a dozen or so lines would be needed, it would be much faster to do directly in Title Editor than DataSource.
But right now, I can't find a way to use the right-click in shortcuts on a particular Input.
Thanks,
hi808
#2 Posted : Tuesday, June 29, 2021 6:10:57 PM(UTC)
hi808
#3 Posted : Tuesday, June 29, 2021 6:45:04 PM(UTC)
until available a thought
With Autohotkey one can skip the selection part as in right click input and be directly in the title editor (confirmed)
With some scripting one might be able to link to that or in combination with windows keypad mouse control codes for the SD
Similar Topics
Shortcut for Title Editors Live Button (General Discussion)
by Rinsky 4/14/2021 9:07:37 AM(UTC)
