ron2210
#1 Posted : Wednesday, December 16, 2020 4:25:30 AM(UTC)
ron2210
India
I'm getting Error "Statements and labels are not valid between 'Select Case' and first 'Case'"
when trying scripting with "Select Case" command in vMix Script
Code:
dim strTest as string = "B"
Select Case strTest
	Case "A"
		Console.WriteLine("Character is A")
	Case "B"
		Console.WriteLine("Character is B")
End Select
Please let me know the proper sytnax for Select Case statements in vMix
Thanks in Advance
Janne Adolfsson
#2 Posted : Tuesday, January 12, 2021 12:06:06 AM(UTC)
Janne Adolfsson
I have the same issue.
Papo
#3 Posted : Tuesday, January 12, 2021 11:34:50 AM(UTC)
Papo
Peru
Greetings, I have not been able to do it but if it is only that you can use the if else or the switch or choose or try to put all the visual basic namespace ..... maybe the select word is a command exclusively used for vmix , it can be the same if you put vmix inside the script as the name of a variable for example .... this should be clarified ..... mmmm
translated from spanish to english
ron2210
#4 Posted : Tuesday, January 12, 2021 1:32:00 PM(UTC)
ron2210
India
I have been using else if for my script,
but the language of the error sounded like there was a syntax problem.
If anyone has any details please clarify
#5 Posted : Friday, June 25, 2021 8:43:45 PM(UTC)
As of 24.0.0.59 Select Case is usable
warning though: Can not "style" the code, need to remove spacing before each "Case"! (Edit: for now)
Code:
Select Case strTest
Case "A"
Case "B"
End Select
Tnx Martin for the usability be it with a little bit to consider
ron2210 on 6/25/2021(UTC)
ron2210
#6 Posted : Friday, June 25, 2021 9:08:36 PM(UTC)
ron2210
India
Thanks for the clarification, I was getting error even after updating. Did not know what was wrong.
Thanks for your help
