I am wondering if there is a way to set up merge to work the same way it works with virtual studios....I find that in regular setups where merge is used, there is a sort of fade done while going from one input to the multiview....but in virtual studios, the transition is clean..... I saw this video using triggers, but it worked on the first use, but does not repeat any other time....
