Instant Replay
Instant replay stingers
Joined: 12/8/2020(UTC) Posts: 9  Location: Larbert Thanks: 2 times
Just wondering if there is an easy way to add a stinger on an instant replay, but then not have a stinger if i show the replay at a later time?
The example i have is when i show the replay seconds after during a game, but we want to show the replay again at half time as our presenters discuss it etc.
Any ideas would be greatly appreciated
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
A stinger does not have to be tied directly to a certain situation.
You can create different stingers and use shortcuts and triggers to determine how and what something does.
For example, one can just be your normal Replay in and Replay out transitions.
Other things could be team, league, network, or other transitions that are completely different.
Reminder when you are building triggers consider whether you will be using a single clip or a playlist. The commands for each or different for play and play selected.
Instant Replay
