Nachesko
#1 Posted : Wednesday, June 16, 2021 6:01:42 AM(UTC)
Nachesko
Argentina
Hello Everybody, I´m new to vmix, I come from another software. I Was wondering how can a do this, i´ve tried with triggers, fades and overlays but can´t seem to find the way:
i have two inputs, input 1 is enabled all time, with music/sound constantly playing. Input 2 is a remote camera that is enabled sometimes, with audio.
I need to show at all times input 1 with audio, but when input 2 recieves audio switch to that (and mute audio input 1). When input 2 stop recieving audio switch to input 1 again
input 1 active
input 2 recieves video and sound
> fade to input 2
input 2 stop audio
> fade to input 1
Until now i have done like this the first part, but can´t seem to find how to return to input 1:
Input2
OnAudioMeterDB6 Fade Input2 Duration 500 Delay 500 Mix 1
OnTransitionIn AudioOff Input1 Duration 500 Delay 500 Mix 1
I suppose that I need a trigger like OnAudioMeterBelowDB18? Maybe there is another way, i have very little experience programming for arduino only
Chris Daum
#2 Posted : Saturday, July 3, 2021 2:22:13 PM(UTC)
Chris Daum
Germany
first of all you have to determine how to find out if In2 Audio is running or not.
I would read out the Vmix XML file and refer to the audio meter "meterF1"
You must find out if this could be the right trigger for the switching and then
Code:
Do
Dim xml as string = API.XML()
Dim x as new system.xml.xmldocument
x.load("http://127.0.0.1:8088/api")
AudioIn2 = (x.SelectSingleNode("//input[2]/@meterF1").InnerText)
If AudioIn2 > "whichever value is a clear signal"
api.function("Fade", input:=2, mix:=0, duration:=500)
api.function("SetVolumeFade", Input:=1, Value:=30,500)
else IF AudioIn2 < "..."
api.function("Fade", Input:= 1 , mix:=0)
api.function("SetVolumeFade", Input:=1, Value:=100,500)
End If
Loop
You could add maybe a bit of sleeps 500ms that makes it a bit smother or extend the durations
in the fade or volume fade...
or at least this would be my try on how to get it done
ask
#3 Posted : Saturday, July 3, 2021 5:40:38 PM(UTC)
ask
The simplest way to achieve this is to use shortcuts. Look at the training videos and the help files.
