Scix
#1 Posted : Tuesday, June 15, 2021 4:40:32 AM(UTC)
Scix
When I try to update the Twitch login, I get the attached error:
vmix error.png (37kb) downloaded 0 time(s).
Using Windows, and my default browser is Chrome, so if it's trying to open a page, that should still work -- is this a Twitch error? Has something changed? Is there a fix or workaround?
vMix HD 23.0.0.67 x64
Tried from two different computers (same account)
Thoughts? Am I the only one?
TDVideoEngineering
#2 Posted : Tuesday, June 15, 2021 5:28:55 AM(UTC)
TDVideoEngineering
Germany
there's been an update for vMix 24... Not quite sure if 23 is still being updated.
Scix
#3 Posted: : Tuesday, June 15, 2021 5:32:50 AM(UTC)
Scix
Oh has there? I have "check for updates on startup" selected, so I assumed I had the latest version. I'll manually update and see if that fixes it, thanks!
EDIT TO ADD: It worked, thanks!
TDVideoEngineering
#4 Posted : Tuesday, June 15, 2021 5:34:42 AM(UTC)
TDVideoEngineering
Germany
Yes, but for version 24. See changelogs.
Scix
#5 Posted : Tuesday, June 15, 2021 5:38:27 AM(UTC)
Scix
That did it, thank you so much!
