Alternate aspect ratio of camera not saving on virtual input
Joined: 7/20/2020(UTC) Posts: 1  Location: 31143 Nicolas Rd, Temecula, CA
We are pretty much newbies at vMix, so maybe someone has a good resolution for us. Our PTZ Optics cameras are all 1920 x 1080, so setting the aspect ratio to “widescreen” is the same as the default of “source”. We made a virtual input and set the aspect ratio of it to “normal” so we could gain a little space to add other inputs via MultiView. This works great, EXCEPT, the virtual input always converts back to widescreen when the configuration is reloaded, even though the config was saved with the virtual input set to “normal” before the save. It’s not the end of the world if I just remember to set it (and a few others) back to “normal” on every startup. I am hoping to be able to keep the original camera input set to either source or widescreen, but having the virtual input remember it should be "normal".
