daveydouble
#1 Posted : Tuesday, June 8, 2021 11:16:16 PM(UTC)
daveydouble
Selecting multiple objects within a layer (such as multiple rectangles) seems to have a bug.
I CAN:
Select multiple within the same layer and 'batch' change the animation type and direction.
I CANNOT:
Select multiple within the same layer and 'batch' change the colour of the objects or axis of animation (for central anchors). In this case the operation will apply to the top object in the layer, but no others, which will remain in their previous state.
It makes a two second job turn into a ten minute job, which when multiplied by the number of titles for a given 'set' turns into hours of work.
#2 Posted : Wednesday, June 9, 2021 3:26:03 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Unfortunately this is not a bug but a missing feature, there was never implemented the ability to bulk change the properties of multiple objects
as this is quite complex due to the different formatting amongst different types of objects.
You can submit a feature request for this over on the Feature Requests forum.
doggy on 6/9/2021(UTC), daveydouble on 6/9/2021(UTC)
Kelvin
#3 Posted : Saturday, June 19, 2021 1:16:58 AM(UTC)
Kelvin
By saving a title using the GTXML format rather than the GTZIP format, I was able to edit the colors of multiple objects rather quickly using the Search and Replace feature of Notepad. That saved me quite a bit of time.
