Dynamic Values for audio bus control
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
Hi Champs, once again Lumberjack scripting is in charge... :-) I understood (thanks to one of doggy´s great examples) I can define several values in a dynamic value, save it and use it during my vmix project. I´m regularely working with several Callers and have scripted a "Talk Back", "Hold" and "Show" preset for each incoming call. The idea is for the talk back preset to set "AudioBusOff" on busses d&e&f&g for these are my active sending busses via Dante and I do not want to send an audio feed to the sound desk while maybe another (in program) call is using one of those busses. And for this defining one dynamic value for further use to all other calls Code:API.Function("SetDynamicValue1",Value:="{m}&{a}")
dim xml as string = API.XML()
x.loadxml(xml)
dim MyValues as string = (x.SelectSingleNode("//dynamic/value1").InnerText)
dim MyVals() as string = MyValues.Split(",")
For i As Integer = 0 To MyVals.Length - 1
api.function("AudioBusOff", input:= 1, value:= "MyVals(i)")
Next
This does only affect bus m (the "{}" use was just another try on search for the correct syntax...) any hint to the correct syntax for controlling multiple audio busses via one dynamic value?
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Throwing something at the wall and see what sticks in not the way ;-) spot the difference Code:API.Function("SetDynamicValue1",Value:="value1,value2,value3,value4")
x.loadxml(xml)
Console.WriteLine(MyVals(i))
Next
x.loadxml(xml)
Console.WriteLine(MyValues)
usefull post https://forums.vmix.com/...udio-busses-but-not-MAIN
Hi doggy, thanks for your reply may look a bit like thrown to the wall :-), wasn´t the plan and I guess I understand what it does Made a little clean up and chopped it into pieces Code:API.Function("SetDynamicValue1",Value:="d,e,f,g")
feeds the dynamic value with "content" (more or less define a variable) Code:dim xml as string = API.XML()
x.loadxml(xml)
reads out the "content" of dynamic value 1 to variable "MyValues" from xml api Code:dim MyVals() as string = MyValues.Split(",")
splits the content to a variable array MyVals() resulting in (schematic) MyVals(0) = d MyVals(1) = e MyVals(2) = f MyVals(3) = g Code:For i As Integer = 0 To MyVals.Length - 1
as there are four "variables" (d,e,f,g) defined this defines the variable array to "MyVals(3)" (see above) ______________________________________________________________________________________________ so, now what it should but doesn´t do Code:
Next
that is, switch audio busses d&e&f&g off for Input 1 But as far as I read there seems to be no way for switching more than one bus per input in one stroke. Cause the idea is to use "MyVals(i)" on the other call inputs as well
guess my "imagination" of what a dynamic value does went the wrong way...
Originally Posted by: Chris Daum  guess my "imagination" of what a dynamic value does went the wrong way... Nothing wrong with your imagination as long as you write the function correctly ;-) yours not working Code:api.function("AudioBusOff", input:= 1, value:= "MyVals(i)")
Mine working Code:api.function("AudioBusOff", Input:= "1", value:= MyVals(i))
doggy, what can I say?? I am stunned. I never before saw the input number as digit in "" in an api command ... but... here the complete script yet without Headset definitions. One might say it looks damn complicated, but I love it! and... until now I never saw a faster, easier way to fill a variable array in VB.net although I have to admit I am not very far in my studies Is there any limit in the number of values you can safe as dynamic value? Code:'1 Definition Variablen
Dim xml as string = API.XML()
Dim x as new system.xml.xmldocument
Dim C1Key as String = ""
Dim SendBusses as String = ""
'7 Definition Dyn Value ("Sendebusse")
api.function("SetDynamicValue1", Value:="d,e,f,g")
'10 Laden XML
x.load("http://127.0.0.1:8088/api")
'13 Auslesen Input Key Call 1& "Sendebusse"
C1Key = (x.SelectSingleNode("//input[1]/@key").InnerText)
SendBusses = (x.SelectSingleNode("//dynamic/value1").InnerText)
'17 Erstellen Variablen Array
Dim SdBs() as String = SendBusses.Split(",")
'20 Audio Bus Set Up Talk Back Call 1
api.function("SoloOn", Input:= C1Key)
api.function("AudioOn", Input:= C1Key)
for i as Integer = 0 to 3
api.function("AudioBusOff", input:= C1Key, Value:= SdBs(i))
next
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Just wanted to say that this is a really useful post by the two of you. I'm definitely going to try and replace my 48+ shortcuts that manage talkback busses for 8 calls with this !
thanks, and as mentioned I haven’t found a better and faster way in VB.net to create a variable array
I am working in command lists and a lot of other stuff where arrays can be extremely useful!!
