vMix Call
RProducer: VMIXCall Control Manager
Joined: 3/25/2020(UTC) Posts: 48  Location: Chichester Was thanked: 10 time(s) in 7 post(s)
RProducer VMIXCall Control Manager Demo. Welcome, a question often asked is having a VMIXCall Manager that can have your callers queue and then bring them into your broadcast. Ideally without sending them links. For example they visit a branded page for the event, enter their details and then enter a queue area. Then when ready you bring then into the event. So Introducing possibly :) the Worlds First VMIXCall Control Manager.. The VMIXCall Control Manager is part of the RProducer (Remote Producer) tool set aimed to simplify event setups using VMIX. Please see the Video Demo showing how RProducer : VMIXCall Control Manager using a bespoke login screen for VMIX Callers / entering a queue and being connected in the VMIXCall service. DEMO VIDEOVarious options can be presented to the caller to complete data for the event they are joining. Once entered into the Call Manager queue you can then bring the Caller into a Green Room, where you enable their connection remotely. This is done either by presenting a Join Call Button or directly connecting the Caller (If automatically open option is used note Browsers do have popup blockers so we have address this issue by a option on the entry form to detect and inform the caller to disable the popup blocker for the call site. The Call Button option as you will see in the demo is not affected by this.) Where we all been sending call links to users, you do not need to pre-assign VMIXCall links, You can select any of your Call channels to connect the caller on. Once connected using your system setup you can speak to the caller and also update their details on their connection form data submitted useful for chat shows where you have callers dial-in. The Caller Name and headline text can also be sent to populate an associated GT Title. Moving the Caller into the Control Manager Live section you are able to end their call by clicking the exit button on the Callers Name and this will then close their Call window and also divert them to a exit webpage of your choice. NEXT STEPS:We have a group of testers who will shortly be trying out the RProducer Service. Our tests so far have been in our own controlled environment, so some real world testing is required over the next week. RProducer toolset will be based on a subscription service and all new tools automatically included. But First lets test it!!I Welcome all your thoughts/input here. You can also contact on: FaceBook RProducerLinkedin
RProducer: VMIXCall Control Manager - Please see the Caller Connection Flow Process picture below:-  RProducer VMIXCall Mananger Caller Process Flow.png (193kb) downloaded 33 time(s).
 1 user thanked Aecast for this useful post.
Joined: 6/19/2021(UTC) Posts: 1  Location: Tunis Thanks: 1 times
Bonjour c'est pour quand le lancement du Vmixcall control manager et est ce qu'il marchera avec quel forme d'abonnement Vmix ( est ce ok pour la forme HD ) ou il sera limité a Vmix pro
Originally Posted by: med ali  Bonjour c'est pour quand le lancement du Vmixcall control manager et est ce qu'il marchera avec quel forme d'abonnement Vmix ( est ce ok pour la forme HD ) ou il sera limité a Vmix pro "Hello when is the launch of the Vmixcall control manager and which form of Vmix subscription will it work with (is this ok for the HD form) or it will be limited to Vmix pro" Bonjour Med Ali, the RProducer VMIXCall Control Manager currently works for VMIX versions 4K and PRO latest releases. We are still testing and release date not set yet. If you would like to try out/test please visit our FaceBook Group here - https://www.facebook.com/groups/rproducer for details BR Ian
vMix Call
