thecloudmediagroup
#1 Posted : Wednesday, May 7, 2014 3:51:43 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
I have a client that I am trying to get streaming through vMix. I installed everything but when I hit "Start" within vMix, it starts the process of starting to stream but never gets to the streaming stats part and then the green button goes back to grey. The only error message is something about the timecode being invalid. However I get the same error on my machine which streams fine.
The weird part is that if I use the external output and stream through FMLE, I have not issues at all. The urls are all correct and there are no typos.
This machine did have VidBlaster on it previously which I uninstalled.
Any ideas?
#2 Posted : Wednesday, May 7, 2014 6:45:46 PM(UTC)
Can you explain in more detail?
Is it similar to the problems talked about in this thread:
http://forums.vmix.com.a....aspx?g=posts&t=2168 ??
Sounds like a mis-cue somewhere in the set-up.
